Is qDslrDashboard only for TP-LINK MR3040?
Re: Is qDslrDashboard only for TP-LINK MR3040?
It will work with any router that is supported by the OpenWrt firmware and the ddserver can be compiled ( https://github.com/hubaiz/DslrDashboardServer )
You can also use with a Raspberry Pi Zero W.
Also try and look around the forum, there are samples of various routers/devices used.
