Interval timer not working on Android
skysurfer
Post by skysurfer »
Using interval timer on QDSL Dashboard 3.5.9 on a Canon 6D is not working anymore.
When I set the camera to B(ulb) and connect it via USB to the Android phone (Xiaomi Mi Pro running MIUI 10 / Android Pie), then I set exposure time (2 sec in this example), interval (3 sec) and 3 frames.
But the start / stop buttons remain grayed out. This used to work in 3.5.8. What is changed ?
And the 'Sky stacking' mode does not allow to fill in the shutter speed anymore. When I click on it I see an empty box with a red cross with no way to fill in anything.
EDIT: I tried the macOS version but that has the same problem: the interval timer or sky stacking is not working with the same issues.
