Need a help
wlayher
Re: Need a help
Post by wlayher »
Do you use live view in qDslrDashboard? If you want to use an external intervalometer, you have to switch off live view. If you use the LRtimelapse function within qDslrDashboard, you don't need live view. It works by loading and evaluating the last jpeg.
Re: Need a help
Is live view activated? The external timer will not work if live view (or host mode) is enabled.
jaswantbro19
Re: Need a help
Post by jaswantbro19 »
I also have this problem ony canon eos 750D with qdslr dashboard v3.5.9 and others, it doesnt matter if i use a cable intervallometer or a wireless.
Would be great if you could help me!
Greets
