Is this still the way to connect to a D850
User avatar
Unfamiliarlight
Post by Unfamiliarlight »
I recently picked up a new camera and about about to start trying to figure this out. It seems that dslrdashboard can do focus stacking for my plain old AF lens. I hope I have read that correctly.
At any rate is this post: viewtopic.php?p=6746#p6746 still the way to make the connection between camera and the app?
Re: Is this still the way to connect to a D850
With the latest firmware you can enable the wireless on camera so you don't need Snapbridge to activate it.
User avatar
Unfamiliarlight
Nice, thanks. I found an article about the firmware that showed how to do that.
I had to turn my mobile data off through to get it to work. Is that something that can be changed?
At any rate I am up and running. I'm sure I'll have a question or two once I start using it.
After the connection is made to the camera from qDD you can enable the mobile data.
User avatar
Unfamiliarlight
OK good to know. It's a bit of a bummer but better than having to leave it off for the duration.
