qDslrDashboard V3.5.9 exit when connect to ddserver V0.2.14
luckylz2dd
Post by luckylz2dd »
Hi, Hubaiz!
I can use the DDServer OpenWrt ar71xx V0.2-13 package & qDslrDashboard V3.5.9 (windows) without any problems.
When I tried to compile the ddserver 0.2.14 with openwrt-sdk-19.07.2-armvirt-64_gcc-7.5.0_musl.Linux-x86_64.tar.xz, and got ddserver installed & run as the following:
opkg update
opkg install libusb-1.0-0_1.0.22-2_aarch64_generic.ipk --force-overwrite
opkg install libstdcpp6_7.5.0-2_aarch64_generic.ipk --force-overwrite
opkg install ddserver_0.2-14_aarch64_generic.ipk
Then I plug my Nikon D810 to the router with USB cable, camera can be recognized:
Tue Apr 21 23:28:41 2020 kern.info kernel: [ 3839.711662] usb 1-2: USB disconnect, device number 6
Tue Apr 21 23:28:46 2020 kern.info kernel: [ 3844.545432] usb 1-2: new high-speed USB device number 7 using xhci-hcd
Tue Apr 21 23:28:46 2020 kern.info kernel: [ 3844.579037] usb 1-2: New USB device found, idVendor=04b0, idProduct=0436, bcdDevice= 1.11
Tue Apr 21 23:28:46 2020 kern.info kernel: [ 3844.581561] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Tue Apr 21 23:28:46 2020 kern.info kernel: [ 3844.588672] usb 1-2: Product: NIKON DSC D810
Tue Apr 21 23:28:46 2020 kern.info kernel: [ 3844.592858] usb 1-2: Manufacturer: NIKON
Tue Apr 21 23:28:46 2020 kern.info kernel: [ 3844.596765] usb 1-2: SerialNumber: 000000201####
But when I try to connect the ddserver using qDslrDashboard V3.5.9 (windows), the program just exit without any error prompt:
Checked the router system log as the following:
Tue Apr 21 23:29:23 2020 user.info : recv: 57
Tue Apr 21 23:29:23 2020 user.info : Client multicast query DslrDashboardClient{3f5b417a-b23f-4461-97f1-5d5928365616}
Tue Apr 21 23:29:23 2020 user.info : Server message length: 57   msg: DslrDashboardServer{3f5b417a-b23f-4461-97f1-5d5928365616}
Tue Apr 21 23:29:25 2020 user.info : Incoming client connection
Tue Apr 21 23:29:25 2020 user.info : Awaiting client connection
Tue Apr 21 23:29:25 2020 user.info : USB Devices in
Tue Apr 21 23:29:25 2020 user.info : Number of possible configurations: 1 Device Class: 0 VendorID: 1200, ProductID: 1078
Tue Apr 21 23:29:25 2020 user.info : Number of alternate settings:
Tue Apr 21 23:29:25 2020 user.info : Interface class: 6 Interface number: 0 Number of endpoints: 3
Tue Apr 21 23:29:25 2020 user.info : Found USB imaging device, get vendor and product
Tue Apr 21 23:29:25 2020 user.info : Device Manufacturer: NIKON
Tue Apr 21 23:29:25 2020 user.info : Device Product: NIKON DSC D810
Tue Apr 21 23:29:25 2020 user.info : Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 3
Tue Apr 21 23:29:25 2020 user.info : Interface class: 9 Interface number: 0 Number of endpoints: 1
Tue Apr 21 23:29:25 2020 user.info : Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Tue Apr 21 23:29:25 2020 user.info : Imaging USB devices found: 1
Tue Apr 21 23:29:25 2020 user.err : Error reading total packet size: 0
Tue Apr 21 23:29:25 2020 user.err : Stoping client
Tue Apr 21 23:29:25 2020 user.info : Checking device with vendorId: 04b0  and productId: 0436
Tue Apr 21 23:29:25 2020 user.info : Trying to open device
Tue Apr 21 23:29:25 2020 user.info : Device  open success
Tue Apr 21 23:29:25 2020 user.info : USB device opened
Tue Apr 21 23:29:25 2020 user.info : Read endpoint adress: 129
Tue Apr 21 23:29:25 2020 user.info : Write endpoint adress: 2
Tue Apr 21 23:29:25 2020 user.info : Interrupt endpoint address: 131
Tue Apr 21 23:29:25 2020 user.info : USB interface claimed
Tue Apr 21 23:29:25 2020 user.info : vendor: 1200 product: 1078
Tue Apr 21 23:29:27 2020 user.info : Closing USB device
Tue Apr 21 23:29:29 2020 user.err : Error command packet USB bulk write: -7
Tue Apr 21 23:29:29 2020 user.err : Stoping client
Tue Apr 21 23:29:31 2020 user.info : Closing USB device
Tue Apr 21 23:29:31 2020 user.info : USB interface released
I guess there might be a chance the compile is not 100% working, but whether you can provide some clues to me?
Thanks in advanced !
