Windows 8.1 not supported?
Oki
Post by Oki »
I would like to try qDslrDashboard with my Canon 7D Mark II built-in wifi before I purchase TP-link TL-WR902AC. I use Windows 8.1 and here comes the error:
"This windows version (6.3.9600) does not support the required Bluetooth API. Consider updating to a more recent Windows (10.0.10586 or above)"
when I try to run it. Does this mean qDslrDashboard only supports Win 10? Is there an option top download older build which supports win 8.1? I have found nothing in documentation/main page regarding supported windows versions. I have also tried to search forum, but "windows" phrase is considered as "too common" to show me some results :roll:
Thank you.
Re: Windows 8.1 not supported?
Should work on Windows 7 and up.
Try this newer build: https://drive.google.com/file/d/1tTBDif ... sp=sharing
Oki
Post by Oki »
Thank you, but I get the same error with V3.6.0 :(
jbress
Post by jbress »
I had the same error under Windows 8.1 x64 (6.3)
I solved it by replacing the Qt5Bluetooth.dll file in the qDD folder by the one from the package qt-opensource-windows-x86-5.9.2.exe
(C:\Qt\Qt5.9.2\5.9.2\msvc2017_64\bin\Qt5Bluetooth.dll) ;)
