Hi There
Apologises if this has before. I have done a search but couldn't seem to find anything relating to it.
The Nikon Z6 allows for High Speed Continuous (Extended) shooting which with the right settings gives you 12 shots per second
Is there a way on QDSL to stop it automatically downloading the image after 1 shot straight to the tablet and allow me to select the number of images i wish to take like on normal High Speed Continuous shotting
Many thanks in advance
High Speed Continuous (extended) Nikon Z6
Re: High Speed Continuous (extended) Nikon Z6
Disable the 'Image review after capture' or 'Quick image review after capture' options in qDslrDashboard settings.
After you enable continuous capture in camera properties display there will be a new button right after the 'capture mode' button where you can set the number of images that will be taken.
Hi Hubaiz
Thank you for your quick response.
I think i have already done this though and still do not get the ability to do this, it is there is i just select High Speed Continuous just not the Extended version
I have attached a couple of screenshots
Screenshot_20200606-114222_qDslrDashboard by Mathew Yardley, on Flickr
Screenshot_20200606-114241_qDslrDashboard by Mathew Yardley, on Flickr
Mat
Mat
Mat Yardley
https://www.flickr.com/photos/matyardley
Will check out with my Z6.
Eventually contact me with the support email.
Thank you, look forward to hearing from you
Mat Yardley
The buffer size may be increased. For quick-paced action photography, 35 lossless compressed RAW shots or 180 JPEG images is not a lot.Yardbrush wrote: ↑05 Jun 2020, 22:25 Hi There
