High Speed Continuous (extended) Nikon Z6
Posted: 05 Jun 2020, 22:25
by Yardbrush
Hi There
Apologises if this has before. I have done a search but couldn't seem to find anything relating to it.
The Nikon Z6 allows for High Speed Continuous (Extended) shooting which with the right settings gives you 12 shots per second
Is there a way on QDSL to stop it automatically downloading the image after 1 shot straight to the tablet and allow me to select the number of images i wish to take like on normal High Speed Continuous shotting
Many thanks in advance
Re: High Speed Continuous (extended) Nikon Z6
Posted: 06 Jun 2020, 09:44
Disable the 'Image review after capture' or 'Quick image review after capture' options in qDslrDashboard settings.
After you enable continuous capture in camera properties display there will be a new button right after the 'capture mode' button where you can set the number of images that will be taken.
Posted: 06 Jun 2020, 11:08
by Yardbrush
Hi Hubaiz
Thank you for your quick response.
I think i have already done this though and still do not get the ability to do this, it is there is i just select High Speed Continuous just not the Extended version
I have attached a couple of screenshots
ImageScreenshot_20200606-114222_qDslrDashboard by Mathew Yardley, on Flickr
ImageScreenshot_20200606-114241_qDslrDashboard by Mathew Yardley, on Flickr
Mat
Posted: 07 Jun 2020, 12:22
Will check out with my Z6.
Eventually contact me with the support email.
Posted: 07 Jun 2020, 17:34
by Yardbrush
Thank you, look forward to hearing from you
Posted: 02 Sep 2020, 06:20
by Falconjurer
hubaiz wrote: ↑07 Jun 2020, 12:22 Will check out with my Z6.
Posted: 15 Sep 2023, 06:59
by joshuaparker279
Yardbrush wrote: ↑05 Jun 2020, 22:25 Hi There
The buffer size may be increased. For quick-paced action photography, 35 lossless compressed RAW shots or 180 JPEG images is not a lot.
