I did a fresh install of raspbian for a rpi4 modelb 2GB. I follow all steps as indicated in the github but I got stuck on those errors. I am not at all familiar how to solve those errors myself.
I buy that rpi just for dslrdashboard.
Please need someone expertise.
pi@raspberrypi:~/DslrDashboardServer $ g++ -Wall src/main.cpp src/communicator.cpp `pkg-config --libs --cflags libusb-1.0` -lpthread -lrt -lstdc++ -o ddserver
src/main.cpp: In function ‘void startUdpListener()’:
src/main.cpp:137:21: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 3 has type ‘ssize_t’ {aka ‘int’} [-Wformat=]
syslog(LOG_INFO, "recv: %ld", bytes);
src/main.cpp: In function ‘void joinGroup(int, char*)’:
src/main.cpp:280:55: warning: comparison of integer expressions of different signedness: ‘in_addr_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
if ((groupStruct.sin_addr.s_addr = inet_addr(group)) == -1)
src/main.cpp: In function ‘void leaveGroup(int, char*)’:
src/main.cpp:302:55: warning: comparison of integer expressions of different signedness: ‘in_addr_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
src/main.cpp:145:12: warning: ‘char* strncpy(char*, const char*, size_t)’ output truncated before terminating nul copying 19 bytes from a string of the same length [-Wstringop-truncation]
strncpy(buf, DD_SERVER, sizeof(DD_SERVER)-1);
src/communicator.cpp:454:3: warning: "/*" within comment [-Wcomment]
In file included from src/communicator.cpp:8:
src/communicator.h: In constructor ‘Communicator::Communicator()’:
src/communicator.h:64:24: warning: ‘Communicator::mHandle’ will be initialized after [-Wreorder]
libusb_device_handle *mHandle;
src/communicator.h:63:17: warning: ‘libusb_device* Communicator::mDevice’ [-Wreorder]
libusb_device *mDevice;
src/communicator.cpp:10:1: warning: when initialized here [-Wreorder]
Communicator::Communicator() : mSocket(0), mCtx(nullptr), //mIsInitialized(false), mIsUsbInitialized(false),
src/communicator.cpp:16:27: warning: ‘void libusb_set_debug(libusb_context*, int)’ is deprecated: Use libusb_set_option instead [-Wdeprecated-declarations]
libusb_set_debug(mCtx, 0); //set verbosity level to 3, as suggested in the documentation
In file included from src/communicator.h:12,
/usr/include/libusb-1.0/libusb.h
void LIBUSB_CALL libusb_set_debug(libusb_context *ctx, int level);
src/communicator.cpp: In member function ‘bool Communicator::readFromClient()’:
src/communicator.cpp:110:9: warning: comparison of integer expressions of different signedness: ‘ssize_t’ {aka ‘int’} and ‘uint32_t’ {aka ‘unsigned int’} [-Wsign-compare]
if (r == (packetSize - 4)) {
src/communicator.cpp:114:20: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 3 has type ‘ssize_t’ {aka ‘int’} [-Wformat=]
syslog(LOG_ERR, "Error reading packet : %ld", r);
src/communicator.cpp:119:19: warning: format ‘%ld’ expects argument of type ‘long int’, but argument 3 has type ‘ssize_t’ {aka ‘int’} [-Wformat=]
syslog(LOG_ERR, "Error reading total packet size: %ld", r);
src/communicator.cpp: In member function ‘bool Communicator::processUsbPacket(uint8_t*, int)’:
src/communicator.cpp:279:16: warning: comparison of integer expressions of different signedness: ‘int’ and ‘__uint32_t’ {aka ‘unsigned int’} [-Wsign-compare]
if (writen != le32toh(header->packet_len))
src/communicator.cpp: In member function ‘uint8_t* Communicator::readUsbPacket(int&, bool)’:
src/communicator.cpp:350:38: warning: comparison of integer expressions of different signedness: ‘int’ and ‘uint32_t’ {aka ‘unsigned int’} [-Wsign-compare]
while(packetSize1 == 0 || totalRead < packetSize1) {
src/communicator.cpp:364:33: warning: comparison of integer expressions of different signedness: ‘uint32_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
if (packetSize1 > currentPacketSize - 4) {
src/communicator.cpp:380:35: warning: comparison of integer expressions of different signedness: ‘int’ and ‘uint32_t’ {aka ‘unsigned int’} [-Wsign-compare]
if (currentPacketSize < 4 + packetSize1 + 128) {
src/communicator.cpp:387:49: warning: comparison of integer expressions of different signedness: ‘int’ and ‘uint32_t’ {aka ‘unsigned int’} [-Wsign-compare]
while(packetSize2 == 0 || totalRead < packetSize2) {
src/communicator.cpp:345:27: warning: unused variable ‘resume’ [-Wunused-variable]
bool isResponse = false, resume = true;
src/communicator.cpp: In member function ‘void Communicator::sendUsbDeviceList(uint32_t)’:
src/communicator.cpp:847:20: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘std::vector<ImagingUsbDevice>::size_type’ {aka ‘unsigned int’} [-Wformat=]
syslog(LOG_INFO, "Imaging USB devices found: %lu", imgUsbDevices.size());
