Focus stacking questions
rz514
Post by rz514 »
Hello!
I just started using this app with my Nikon D7200 and have a few questions for focus stacking...
What is FOCUS STEPS? i do not understand what "Focus Step is the amount the lens focus ring will be moved" .. what does this mean and how does this apply while taking a picture?
Also, it happens often that the focus goes out of focus after the 1st shot, i don't understand why it does this since both focus points were properly set?
thanks in advance
Re: Focus stacking questions
please check this thread: viewtopic.php?f=6&t=1276
rz514
Post by rz514 »
yes i posted this after reading that thread... i do not understand what that means. can you explain?
Not sure how could I explain it, it is the amount of the movement that is applied to the lens focus ring.
What settings did you use? Can you reproduce? Maybe a picture that demonstrates the problem?
