Specify another ip address
marcojj
Post by marcojj »
Hi, is it possible on the mac application specify another ip address, not only 192.168.1.1 ?
I use an imac connected by ethernet and obviously the router is 192.168.1.1. When I connect the tplink via wifi there is an ip conflict.
It should be great. Is there a way to edit a preferences file? thanks! marco
Re: Specify another ip address
You can long press the 'Network' button and enter the IP address for connection.
To change the MR3040 IP address you will need to do it in OpenWrt web interface.
marcojj
Post by marcojj »
Great! thanks!!! But it doesn't save the ip, everytime I have to put it manually
