Please help, Auto Holy Grail results too dark
Posted: 09 Feb 2021, 00:00
by tokyoshot
today I was shooting a blue hour-to-night transition using ControlMyCamera, iPhone 11 and R5.
Shooting interval 5", longest exposure set to 2", electronic shutter 1st curtain, using Canon TC-80N3 intervalometer.
Initial capture settings were 1/5, F4 and ISO 100 - slightly underexposed in order not to protect highlights.
Auto holy grail and NTC (2.0) were selected and I've started the sequence. After I've noticed images got too dark I have manually corrected the exposure on the camera (the + button in ControlMyCamera didn't react). Even though the sequence was underexposed around 2,5 stops at the end - the initial settings didn't change at all.
I've already successfully accomplished several holy grail transitions with the same setup so I'm really confused what happened.
I would be very grateful to get some advice.
Thanks in advance.
Krzysztof
www.tokyoshot.com
Re: Please help, Auto Holy Grail results too dark
Posted: 09 Feb 2021, 09:42
According your last image the 'Auto holy grail' was not enabled.
Posted: 09 Feb 2021, 14:41
by tokyoshot
Thank, it’s correct. I’ve taken this screenshot after going in full manual mode adjusting the camera by myself. Before that it was activated. I should have written that in my original post.
Posted: 09 Feb 2021, 21:03
Ok, does the intervalometer enable the camera autofocus between the captures?
Posted: 09 Feb 2021, 23:29
by tokyoshot
I was using Canon TC 80N3, always trying to allow at least 2" between the longest shutter speed end the end of the given interval.
Today I started 3 new sequences with Auto Holy Grail.
-4" longest shutter speed and 15" interval: worked out perfectly
-6" longest shutter speed and 15" interval: worked out perfectly
-6" longest shutter speed and 8" interval: didn't work
So, ok, that could be an explanation for today - 2" were not enough.
But yesterday I had an 5" interval and the shutter speed didn't exceed 1/5".
I'll be getting the LRT Pro Timer on Friday anyway, maybe my problem would get solved by the new intervalometer.
Thank you for your support!
