first: sorry for my bad englisch
and now:
i have an 6d mk ii and two 70d. 70d is everything fine. but if the 6d is connected, i push the trigger, for example the "capture sample" button and then the 6d does not stop to capture till i pull out the cable.
in wifi i have the same problems.
the options "use android native usb" or the "use canon local storage" brings also no effect.
thx in advance!
greets
martin
