Sony A7Siii
Tegels038
Sony A7Siii
Post by Tegels038 »
Will it be possible to connect with the Sony A7Siii in the future?
Re: Sony A7Siii
If it supports the 'Smart remote control' camera application ( https://www.playmemoriescameraapps.com/ ... _00-F00002 ) then yes.
Tegels038
Re: Sony A7Siii
Post by Tegels038 »
Thnx for the reply!
But a bit confusing answer... ;) Do you mean it is going to work or should it already work? When I try to connect my A7Siii to qdslrdashboard, it will find my camera but it can’t connect.
No problems with connecting to the Sony app!
kruki
Re: Sony A7Siii
Post by kruki »
@hubaiz,
the same SDK as for the Sony A7 RIV could also be used for the A7SIII.
I think the old playmemories route is a dead end. Any of the recent (higher end) Sony cameras support the new SDK only. Please see supported cameras from the link below. A year ago Sony announced the SDK for the A7 RIV. In the meantime they have added 6 additional cameras:
https://support.d-imaging.sony.co.jp/ap ... index.html
Supported device
ILCE-1, ILCE-9M2, ILCE-7RM4A, ILCE-7RM4, ILCE-7SM3, ILCE-7C
DSC-RX0M2 (Ver. 3.00 or later)
Any chance to add support ? I would be willing to help you with testing ...
Re: Sony A7Siii
If it uses the new Sony communication protocol then it will not work.
I'm trying to implement it but without proper documentation it is hard.
robertoruiz
Re: Sony A7Siii
Post by robertoruiz »
I just bought the Sony a7s iii and found the same issue to connect. Please comment if this issue has been resolved.
