Interval timer with in-camera wifi gets hangs??
KirenPollard
Post by KirenPollard »
I am using QDD V3.5.3, a Nikon D5300 and an HP EliteBook Windows10 PC.
I start the in-camera wifi network and connect the PC to it. I then start QDD and
do a Nikon connect. Then I start the Nikon Life View from QDD. So far so good!
The next thing I do is to start the Interval Timer with the following settings:
- Frame Count0
- Interval 5min
- Bulb Time 1sec
The first capture is performed OK, but at the second shot, everything hangs and the
message "Capture in progress" is showing forever. It never recovers from that, so I
have to close everything down and start from the beginning again.
It does not matter which values I use, the result is always a forever hang...
Re: Interval timer with in-camera wifi gets hangs??
Can you try a longer interval, like 7-8 seconds
