Nikon D800 and Connectivity
SHYBULL
Post by SHYBULL »
I apologize in advance, I am quite the amateur at this kind of thing. I purchased the TP-3040 wireless devise and flashed it per the instructions on the video supplied. I successfully did this, however the TP-3040 was on 3G/4G when I did this. It would not connect to the camera. So I did a "sys" upgrade on the TP-3040 (flashed it with the upgrade) withe the devise set to AR setting. No luck. Do I need to upgrade the DDSERVER PACKAGE UPDATER? And just so I'm clear, all I need to do is connect the TP-3040 to my camera (Nikon D800) via the USB cable? The software for camera control is installed on my iPhone 6.
Thank you in advance.
Re: Nikon D800 and Connectivity
Did you use the OpenWrt firmware downloaded from here: http://dslrdashboard.info/downloads/
From your web browser can you access the OpenWrt web interface at http://192.168.1.1 ?
SHYBULL
Post by SHYBULL »
Yes I did download the OpenWrt and was able to access the interface. I think I screwed it up the first time. I got another TP-Link3040 and flashed it "correctly" this time (on the AP setting, not the 3g/4G) I got it to work with a Samsung Galaxy Tab4 (Android), but still not with my iPhone. After getting it to work on the Galaxy, I tried my iPhone again and still the TP-Link could not find my Nikon D800. It should be able to work with both correct? Thanks for your reply and help.
Yes
Did you try on iPhone to long press the 'Network' button and enter 192.168.1.1 and then press the 'Connect' button ?
SHYBULL
Post by SHYBULL »
It finally worked. Thank you!
