I use the 3.0 version with a Nikon D750 on an Ipad mini.
Everything works quit nice except when I use the Bracketing function, the bracketing goes well but when it is finished it is not possible
to focus any more. The little icons for manually focus are no more on the screen neither.
The only way to get it back working is to leave LV and restart LV again. (This also happened in the 2.9 Version)
Any ideas?
Mark
PS Love your program, excellent app!
						No More Focus after Bracketing
Re: No More Focus after Bracketing
I know about this problem and it will be fixed.
Currently you can fix it by going into 'camera properties display' after bracketing finished and change the focus mode from MF to AF-S
or you just deactivate and activate liveview again
In the latest version of qDslrDashboard v0.3.3, the Bracketing Focus issue is completely solved and works perfect!
Thanks again for the excellent follow up of this problem.
Markem
Markem
