Program is excellent fr use with tilt/shift lenses, especially for tilt when checking the focus across the image plane and it would be really useful in amongst the calculators you have the pre was one that enabled us to get the starting tilt angle given the height above the subject and distance from it.
I think it is called the Scheimflug principle and that this is used for the calculations. There are apps for this, but not built into DSLRDashboard which is where I would use it
Tilt/Shift calculator
Re: Tilt/Shift calculator
Bumping this feature request in the hope that Zoltan sees it and perhaps can include it within the calculators in the program
The app I referred to earlier doesn't work on ios9 and the author seems to have disappeared so this feature is really needed by me at least now
