Tilt/Shift calculator
Posted: 03 Oct 2015, 04:49
Program is excellent fr use with tilt/shift lenses, especially for tilt when checking the focus across the image plane and it would be really useful in amongst the calculators you have the pre was one that enabled us to get the starting tilt angle given the height above the subject and distance from it.
I think it is called the Scheimflug principle and that this is used for the calculations. There are apps for this, but not built into DSLRDashboard which is where I would use it
