Tethering Sony Alpha A7RII with brackets..
sachagriffin
How does one tether with this camera and use brackets? The Bracket button fails to work.
Re: Tethering Sony Alpha A7RII with brackets..
If you tether you use camera controls in camera, qDD is just for viewing photos.
If you use qDD for remote control you use controls from qDD. With Sony you have limited functionality because Sony does not provide full functionality with remote control.
Also you have 2 option for bracketing - built in camera (may not work) and "custom bracketing" where qDD takes over and sets times.
Second one should work because it is nothing else than changing time manually.
