Adjust delay between bracketing shots?
ianc
Post by ianc »
Hi there,
First off, thanks for the fabulous software; it's flat out stupendous!
I've been trying out the Custom Bracketing feature on my D3300 (Nikon must have forgot it, har har), and have noticed that there's a rather long delay of perhaps 3 sec or so between successive shots. This increases the likelihood of some kind of movement occurring during the sequence, and so I wondered if there's a way to adjust this delay?
I can't seem to find anything in the docs about it. Is it possible? Thanks for any suggestions!
Ian
Re: Adjust delay between bracketing shots?
No, there is not such feature.
It is a delay from camera, it needs time to write the capture image to the SD card.
ianc
Post by ianc »
Hmm.... I think not. This camera can fire 5 fps, but the delay between individual exposures in bracketing mode is more like 3-5 sec, so something else is going on.
Still, if it can't be adjusted, it can't be adjusted. Thanks for your reply,
Ian
Yes I know that the camera can capture with 5 fps but while the camera is controlled over USB/wifi (PTP) it is working a bit different.
The camera will not allow to start a new capture while the started capture is finished (capture + write image to SD card).
