Live View Vs 16x9 - Need Crop Marks?
amcweeny
Post by amcweeny »
I'm using a Nikon D7000. When I use DslrDashboard using my Nexus 7 Android Tab as a field monitor I've noticed that what I appear to be capturing vs what I actually capture is no the same. There is no 16 x 9 'crop mask' on the Live View image so top and bottom get cropped. Am I missing something or is this something that needs to be added?
Andrew
Re: Live View Vs 16x9 - Need Crop Marks?
Not sure what you mean, if you mean aspect ratio display you can enable it in 'Camera properties display' under 'Live view' category.
Please check the manual available here: http://dslrdashboard.info/downloads/
amcweeny
Post by amcweeny »
Thanks for pointing that setting out. That's what I was looking for.
Excellent App! Keep up the great work.
amcweeny
Post by amcweeny »
I just found out that the LiveView Aspect Ratio overlay ONLY works when the LiveView Grid is active. I normally turn the grid off and this is why I'm not seeing the 16x9 overlay. Could you include a fix for this in your next release?
Thanks.
Yes, will fix it
