Canon 5D Mark III - Image on seperate Cards
Aquablue71
Post by Aquablue71 »
i got my device yesterday and start playing around with it.
I am using a Canon 5D Mark III together with an IPad 2 and the latest Version of qDSLRDashboard.
So far everything seems working fine. Of course i have to get used to the App to be more professional with it.
But i found some strange behavior. I set my camera to shot RAW and JPG an separate Cards (RAW on CF, JPG on SD).
Now when i make a Image (regardless if i start from the cam or from the App) the App transfers both files. As you can imagine this can take a while (not really working for shootings). So far i did not found any option to tell the app just to get the JPG. After a while i changed my cam settings, that everything will be stored on one card (not the best solution for a good shooting. With this option it is not possible to hand out the images very fast). That seems working now. After changing that i got just the JPG images, but no RAW anymore. After changing the resolution to S i got the images in a few seconds. So this seems like working. But on long terms i would prefere to have my images on different cards.
Did i setup something wrong or is this feature not working correctly right now on Ipad?
Thanks for the help
Regards
André
Re: Canon 5D Mark III - Image on seperate Cards
Will check this.
Unfortunately Canon does not provide documentation for developers and only have the 650D for testing and it only have one card slot.
Aquablue71
would be great :)
If i can help you with anything let me know.
But i have additional Problems with a Crashing app. I will create a second ticket for that.
