I am using qDlsrDashboard (OSx) and ControlMyCamera (ios).
Both works fine (USB/WiFi OSX and WiFi on Ios)) with my D750.
The new Nikon Z7 does not work with Wifi on OS X and Ios as well.
see attachments
USB on OS x with the Z7 works fine.
Can you please help?
Problem with Niko Z7 and WiFi
- Z7_Screen.JPG (95.89 KiB) Viewed 15109 times
- Black_Screen 2019-06-07 um 11.49.36.png (89.78 KiB) Viewed 15109 times
- Bildschirmfoto 2019-06-07 um 11.49.10.png (105.83 KiB) Viewed 15109 times
Re: Problem with Niko Z7 and WiFi
Please try this newer build: http://bit.ly/2EXa2xe
Unfortunately there are some options to start wifi on the Z7 (I assume the same is valid for the Z6).
The correct way (this works in my case) is the following:
In both cases (ios and os x as well) select "connect to smart device" not to computer
Then dslrdashboard and ConrollMyCamera work as expected.
fritz
fritz
Yes correct, for wireless connection you should always use the 'Connect to smart device' option.
