Page 2 of 2
Re: DDServer not found / MR3020 / D90
Posted: 21 Apr 2017, 22:04
by sndrgn
What's wrong?
Posted: 23 Apr 2017, 12:04
by sndrgn
Mon Jan 23 10:56:09 2017 user.info syslog: Incoming client connection
Mon Jan 23 10:56:09 2017 user.info syslog: Awaiting client connection
Mon Jan 23 10:56:09 2017 user.info syslog: USB Devices in
Mon Jan 23 10:56:09 2017 user.info syslog: Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Mon Jan 23 10:56:09 2017 user.info syslog: Number of alternate settings:
Mon Jan 23 10:56:09 2017 user.info syslog: Interface class: 9 Interface number: 0 Number of endpoints: 1
Mon Jan 23 10:56:09 2017 user.info syslog: Imaging USB devices found: 0
Mon Jan 23 10:56:09 2017 user.err syslog: Error reading total packet size: 0
Mon Jan 23 10:56:09 2017 user.err syslog: Stoping client
Mon Jan 23 10:56:11 2017 user.info syslog: Closing USB device
Mon Jan 23 10:56:26 2017 user.info syslog: Incoming client connection
Mon Jan 23 10:56:26 2017 user.info syslog: Awaiting client connection
Mon Jan 23 10:56:26 2017 user.info syslog: USB Devices in
Mon Jan 23 10:56:26 2017 user.info syslog: Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Mon Jan 23 10:56:26 2017 user.info syslog: Number of alternate settings:
Mon Jan 23 10:56:26 2017 user.info syslog: Interface class: 9 Interface number: 0 Number of endpoints: 1
Mon Jan 23 10:56:26 2017 user.info syslog: Imaging USB devices found: 0
Mon Jan 23 10:56:26 2017 user.err syslog: Error reading total packet size: 0
Mon Jan 23 10:56:26 2017 user.err syslog: Stoping client
Mon Jan 23 10:56:28 2017 user.info syslog: Closing USB device
Posted: 25 Apr 2017, 09:16
by sndrgn
Alone in the dark, nobody out here. :-/
Posted: 28 Apr 2017, 09:10
Do you connect your D90 to the MR3020 full size USB port?
Can you try another USB cable?
From the logs I can only see that the D90 is not recognised, either it is not connected or the cable you are using is wrong or to long.
Posted: 28 Apr 2017, 09:11
Eventually try and flash again the 'sysupgrade' image for the MR3020 following the update instructions:
https://dslrdashboard.info/tp-link-mr30 ... e-upgrade/
Posted: 02 May 2017, 09:11
by sndrgn
Posted: 02 May 2017, 09:33
Glad you managed it.
Posted: 04 May 2017, 18:30
by sndrgn
yes, now after all thiese efforts I can start taking timelapses! I am happy, we can handle it, it seemes that the problem was caused mainly by the cable.
All the best and have a good time!
Chris
