Hi, I am getting crazy with the MR3020 and my Nikon D90. I flashed yet the router one million times (https://dslrdashboard.info/download/dds ... ysupgrade/) The connection via WIFI is working instantly, but then I cannot go further. When I try to connect with my iPhone 6 I get the message "DDServer not found, connecting to IP 102.168.1.1". When I click on the Nikon icon, I get "Error getting DSLR list from IP: 192.168.1.1". The D90 is connected via USB cable to 3G/4G USB port.
What is going wrong here?
Thanks for your help, Chris
DDServer not found / MR3020 / D90
Re: DDServer not found / MR3020 / D90
The 'Nikon wireless' button is only used with Nikon DSLR that have built in wireless or use the WU-1a/1b adapter.
For ddserver you need to use the 'Network' button.
connecting to IP 102.168.1.1" << I guess you entered the wrong IP, it should be 192.168.1.1 by default.
Try and long press the 'Network' button and enter 192.168.1.1 in the IP dialog and finally press the 'Ok' button.
Hi, I am afraid, but I mistyped the IP. I have the original 192.168.1.1. Maybe there is something with the firewall, that the port is blocked? I read a forum thread some days ago....
Not sure what firewall, only if you have one on your iPhone.
Can you connect to the MR3020 wireless from your iPhone (should be DDServerAP by default) ?
After connecting to the MR3020 wireless open a web browser on your iPhone and navigate to http://192.168.1.1
You should get the OpenWrt web administration interface, do you get that?
I tested it, the connection via WIFI works on Laptop and iPhone, The connection to the Interface on http://192.168.1.1/cgi-bin/luci works on Laptop and on iPhone (safari). The DSLRDashboard still tells me, "DDServer not found".
Open the OpenWrt web interface and navigate to System->Software
In the list do you have a package with name 'ddserver' ?
Yes, the ddserver 0.2-14
Do the following:
- power on the MR3020 and wait till it boots
- connect your D90 with USB cable to the full size USB port on the MR3020 (try to use the original cable that you get with your D90 or a shorter one)
- power on your D90
- connect your controlling device and navigate to the OpenWrt web interface (http://192.168.1.1)
- navigate to 'Status'->'System log' and scroll down to the end
you should see something like this:
Do you have it?
- power on your D90
Apr 5 09:25:34 Arduino kern.info kernel: [4798140.530000] usb 1-1.1.4: USB disconnect, device number 63
Apr 5 14:00:51 Arduino kern.info kernel: [4814656.960000] usb 1-1.1.4: new high-speed USB device number 64 using ehci-platform
Apr 5 14:00:51 Arduino kern.info kernel: [4814657.070000] usb 1-1.1.4: New USB device found, idVendor=04b0, idProduct=0430
Apr 5 14:00:51 Arduino kern.info kernel: [4814657.070000] usb 1-1.1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Apr 5 14:00:51 Arduino kern.info kernel: [4814657.070000] usb 1-1.1.4: Product: NIKON DSC D7100
Apr 5 14:00:51 Arduino kern.info kernel: [4814657.080000] usb 1-1.1.4: Manufacturer: NIKONRe: DDServer not found / MR3020 / D90
Hi, thanks for helping. In the system log there is nothing about Nikon or so, here is the complete system log:
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.000000] Linux version 3.18.45 (hubaiz@vmmint) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49389) ) #1 Mon Jan 23 11:42:41 CET 2017
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] MyLoader: sysp=5306ac2e, boardp=8e303482, parts=f904f9ea
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] bootconsole [early0] enabled
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] CPU0 revision is: 00019374 (MIPS 24Kc)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] SoC: Atheros AR9330 rev 1
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Determined physical RAM map:
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] memory: 02000000 @ 00000000 (usable)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Zone ranges:
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Normal [mem 0x00000000-0x01ffffff]
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Movable zone start for each node
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Early memory node ranges
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] node 0: [mem 0x00000000-0x01ffffff]
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x00000000-0x01ffffff]
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] On node 0 totalpages: 8192
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] free_area_init_node: node 0, pgdat 803660f0, node_mem_map 81000000
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] Normal zone: 64 pages used for memmap
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] Normal zone: 8192 pages, LIFO batch:0
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 8128
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.000000] Kernel command line: board=TL-MR3020 console=ttyATH0,115200 rootfstype=squashfs,jffs2 noinitrd
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.000000] Memory: 28392K/32768K available (2523K kernel code, 143K rwdata, 540K rodata, 240K init, 188K bss, 4376K reserved)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] NR_IRQS:51
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Clocks: CPU:400.000MHz, DDR:400.000MHz, AHB:200.000MHz, Ref:25.000MHz
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.000000] Calibrating delay loop... 265.42 BogoMIPS (lpj=1327104)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.080000] pid_max: default: 32768 minimum: 301
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.080000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.090000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.100000] NET: Registered protocol family 16
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.100000] MIPS: machine is TP-LINK TL-MR3020
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.360000] Switched to clocksource MIPS
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.370000] NET: Registered protocol family 2
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.370000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.370000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.370000] TCP: Hash tables configured (established 1024 bind 1024)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.380000] TCP: reno registered
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.380000] UDP hash table entries: 256 (order: 0, 4096 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.390000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.400000] NET: Registered protocol family 1
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 0.400000] PCI: CLS 0 bytes, default 32
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.400000] futex hash table entries: 256 (order: -1, 3072 bytes)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.420000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.430000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.440000] msgmni has been set to 55
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.450000] io scheduler noop registered
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.450000] io scheduler deadline registered (default)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.460000] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.470000] ar933x-uart: ttyATH0 at MMIO 0x18020000 (irq = 11, base_baud = 1562500) is a AR933X UART
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.470000] console [ttyATH0] enabled
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.480000] bootconsole [early0] disabled
Mon Jan 23 10:46:27 2017 kern.warn kernel: [ 0.490000] m25p80 spi0.0: found w25q32, expected m25p80
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.500000] m25p80 spi0.0: w25q32 (4096 Kbytes)
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.500000] 5 tp-link partitions found on MTD device spi0.0
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.510000] Creating 5 MTD partitions on "spi0.0":
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.510000] 0x000000000000-0x000000020000 : "u-boot"
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.520000] 0x000000020000-0x00000013aa5c : "kernel"
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.520000] 0x00000013aa5c-0x0000003f0000 : "rootfs"
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.530000] mtd: device 2 (rootfs) set to be root filesystem
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.530000] 1 squashfs-split partitions found on MTD device rootfs
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.540000] 0x000000380000-0x0000003f0000 : "rootfs_data"
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.550000] 0x0000003f0000-0x000000400000 : "art"
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 0.550000] 0x000000020000-0x0000003f0000 : "firmware"
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 0.570000] libphy: ag71xx_mdio: probed
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.170000] ag71xx ag71xx.0: connected to PHY at ag71xx-mdio.1:04 [uid=004dd041, driver=Generic PHY]
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.180000] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode:MII
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.180000] TCP: cubic registered
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.180000] NET: Registered protocol family 17
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.190000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.200000] 8021q: 802.1Q VLAN Support v1.8
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.210000] VFS: Mounted root (squashfs filesystem) readonly on device 31:2.
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 1.220000] Freeing unused kernel memory: 240K (80384000 - 803c0000)
Mon Jan 23 10:46:27 2017 user.info kernel: [ 2.540000] init: Console is alive
Mon Jan 23 10:46:27 2017 user.info kernel: [ 2.540000] init: - watchdog -
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 3.950000] usbcore: registered new interface driver usbfs
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 3.950000] usbcore: registered new interface driver hub
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 3.960000] usbcore: registered new device driver usb
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 3.970000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 3.980000] ehci-platform: EHCI generic platform driver
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 3.980000] ehci-platform ehci-platform: EHCI Host Controller
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 3.990000] ehci-platform ehci-platform: new USB bus registered, assigned bus number 1
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 4.000000] ehci-platform ehci-platform: irq 3, io mem 0x1b000000
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 4.020000] ehci-platform ehci-platform: USB 2.0 started, EHCI 1.00
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 4.020000] hub 1-0:1.0: USB hub found
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 4.020000] hub 1-0:1.0: 1 port detected
Mon Jan 23 10:46:27 2017 user.info kernel: [ 4.620000] init: - preinit -
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 5.420000] random: procd urandom read with 8 bits of entropy available
Mon Jan 23 10:46:27 2017 kern.notice kernel: [ 8.630000] jffs2: notice: (334) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Mon Jan 23 10:46:27 2017 user.info kernel: [ 8.640000] mount_root: switching to jffs2 overlay
Mon Jan 23 10:46:27 2017 user.info kernel: [ 8.700000] procd: - early -
Mon Jan 23 10:46:27 2017 user.info kernel: [ 8.700000] procd: - watchdog -
Mon Jan 23 10:46:27 2017 user.info kernel: [ 9.430000] procd: - ubus -
Mon Jan 23 10:46:27 2017 user.info kernel: [ 10.440000] procd: - init -
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.460000] NET: Registered protocol family 10
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.480000] ip6_tables: (C) 2000-2006 Netfilter Core Team
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.500000] Loading modules backported from Linux version v4.4-rc5-1913-gc8fdf68
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.500000] Backport generated by backports.git backports-20151218-0-g2f58d9d
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.510000] ip_tables: (C) 2000-2006 Netfilter Core Team
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.530000] nf_conntrack version 0.5.0 (447 buckets, 1788 max)
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.580000] xt_time: kernel timezone is -0000
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.700000] PPP generic driver version 2.4.2
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.710000] NET: Registered protocol family 24
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 11.770000] ath: EEPROM regdomain: 0x0
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 11.770000] ath: EEPROM indicates default country code should be used
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 11.770000] ath: doing EEPROM country->regdmn map search
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 11.770000] ath: country maps to regdmn code: 0x3a
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 11.770000] ath: Country alpha2 being used: US
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 11.770000] ath: Regpair used: 0x3a
Mon Jan 23 10:46:27 2017 kern.debug kernel: [ 11.780000] ieee80211 phy0: Selected rate control algorithm 'minstrel_ht'
Mon Jan 23 10:46:27 2017 kern.info kernel: [ 11.790000] ieee80211 phy0: Atheros AR9330 Rev:1 mem=0xb8100000, irq=2
Mon Jan 23 10:46:32 2017 authpriv.info dropbear[773]: Not backgrounding
Mon Jan 23 10:46:34 2017 user.emerg syslog: setting up led USB
Mon Jan 23 10:46:34 2017 user.emerg syslog: setting up led WLAN
Mon Jan 23 10:46:34 2017 user.emerg syslog: setting up led LAN
Mon Jan 23 10:46:34 2017 user.emerg syslog: start
Mon Jan 23 10:46:34 2017 user.emerg syslog: Saving PID 846 to /var/run/ddserver.pid
Mon Jan 23 10:46:34 2017 user.emerg syslog: Ok
Mon Jan 23 10:46:34 2017 daemon.info procd: - init complete -
Mon Jan 23 10:46:35 2017 user.info syslog: DslrDashboardServer starting
Mon Jan 23 10:46:35 2017 user.info syslog: Starting socket server on port 4757
Mon Jan 23 10:46:35 2017 user.info syslog: Awaiting client connection
Mon Jan 23 10:46:35 2017 user.info syslog: Starting UDP listener
Mon Jan 23 10:46:35 2017 user.info syslog: join multicast group: 224.1.2.3
Mon Jan 23 10:46:35 2017 user.err syslog: error in joining multicast group -1
Mon Jan 23 10:46:35 2017 kern.info kernel: [ 22.730000] device eth0 entered promiscuous mode
Mon Jan 23 10:46:35 2017 kern.info kernel: [ 22.730000] IPv6: ADDRCONF(NETDEV_UP): br-lan: link is not ready
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Interface 'lan' is enabled
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Interface 'lan' is setting up now
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Interface 'lan' is now up
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Interface 'loopback' is enabled
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Interface 'loopback' is setting up now
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Interface 'loopback' is now up
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Network device 'lo' link is up
Mon Jan 23 10:46:35 2017 daemon.notice netifd: Interface 'loopback' has link connectivity
Mon Jan 23 10:46:36 2017 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Mon Jan 23 10:46:37 2017 daemon.notice netifd: radio0 (862): Configuration file: /var/run/hostapd-phy0.conf
Mon Jan 23 10:46:37 2017 kern.info kernel: [ 24.730000] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
Mon Jan 23 10:46:37 2017 kern.info kernel: [ 24.750000] device wlan0 entered promiscuous mode
Mon Jan 23 10:46:37 2017 daemon.notice netifd: radio0 (862): Using interface wlan0 with hwaddr 60:e3:27:b6:4d:88 and ssid "DDServerAP"
Mon Jan 23 10:46:37 2017 kern.info kernel: [ 24.780000] br-lan: port 2(wlan0) entered forwarding state
Mon Jan 23 10:46:37 2017 kern.info kernel: [ 24.790000] br-lan: port 2(wlan0) entered forwarding state
Mon Jan 23 10:46:37 2017 kern.info kernel: [ 24.790000] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Mon Jan 23 10:46:37 2017 daemon.notice netifd: Bridge 'br-lan' link is up
Mon Jan 23 10:46:37 2017 daemon.notice netifd: Interface 'lan' has link connectivity
Mon Jan 23 10:46:37 2017 daemon.notice netifd: radio0 (862): wlan0: interface state UNINITIALIZED->ENABLED
Mon Jan 23 10:46:37 2017 daemon.notice netifd: radio0 (862): wlan0: AP-ENABLED
Mon Jan 23 10:46:37 2017 kern.info kernel: [ 24.810000] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Mon Jan 23 10:46:37 2017 daemon.notice netifd: Network device 'wlan0' link is up
Mon Jan 23 10:46:39 2017 kern.info kernel: [ 26.790000] br-lan: port 2(wlan0) entered forwarding state
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq[1003]: started, version 2.73 cachesize 150
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq[1003]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq[1003]: DNS service limited to local subnets
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq-dhcp[1003]: DHCP, IP range 192.168.1.100 -- 192.168.1.249, lease time 12h
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq[1003]: using local addresses only for domain lan
Mon Jan 23 10:46:41 2017 daemon.warn dnsmasq[1003]: no servers found in /tmp/resolv.conf.auto, will retry
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq[1003]: read /etc/hosts - 1 addresses
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq[1003]: read /tmp/hosts/dhcp - 1 addresses
Mon Jan 23 10:46:41 2017 daemon.info dnsmasq-dhcp[1003]: read /etc/ethers - 0 addresses
Mon Jan 23 10:46:51 2017 daemon.info hostapd: wlan0: STA f0:99:bf:6f:97:97 IEEE 802.11: authenticated
Mon Jan 23 10:46:51 2017 daemon.info hostapd: wlan0: STA f0:99:bf:6f:97:97 IEEE 802.11: associated (aid 1)
Mon Jan 23 10:46:52 2017 daemon.info dnsmasq-dhcp[1003]: DHCPREQUEST(br-lan) 192.168.1.129 f0:99:bf:6f:97:97
Mon Jan 23 10:46:52 2017 daemon.info dnsmasq-dhcp[1003]: DHCPACK(br-lan) 192.168.1.129 f0:99:bf:6f:97:97 sndrgn--iPhone6
Mon Jan 23 10:46:57 2017 kern.notice kernel: [ 45.180000] random: nonblocking pool is initialized
Mon Jan 23 10:47:39 2017 daemon.info hostapd: wlan0: STA c4:b3:01:d9:42:d5 IEEE 802.11: authenticated
Mon Jan 23 10:47:39 2017 daemon.info hostapd: wlan0: STA c4:b3:01:d9:42:d5 IEEE 802.11: associated (aid 2)
Mon Jan 23 10:47:39 2017 daemon.info dnsmasq-dhcp[1003]: DHCPREQUEST(br-lan) 192.168.1.111 c4:b3:01:d9:42:d5
Mon Jan 23 10:47:39 2017 daemon.info dnsmasq-dhcp[1003]: DHCPACK(br-lan) 192.168.1.111 c4:b3:01:d9:42:d5 Akasha2017
Mon Jan 23 10:49:14 2017 user.info syslog: Incoming client connection
Mon Jan 23 10:49:14 2017 user.info syslog: Awaiting client connection
Mon Jan 23 10:49:14 2017 user.info syslog: USB Devices in
Mon Jan 23 10:49:14 2017 user.info syslog: Number of possible configurations: 1 Device Class: 9 VendorID: 7531, ProductID: 2
Mon Jan 23 10:49:14 2017 user.info syslog: Number of alternate settings:
Mon Jan 23 10:49:14 2017 user.info syslog: Interface class: 9 Interface number: 0 Number of endpoints: 1
Mon Jan 23 10:49:14 2017 user.info syslog: Imaging USB devices found: 0
Mon Jan 23 10:49:14 2017 user.err syslog: Error reading total packet size: 0
Mon Jan 23 10:49:14 2017 user.err syslog: Stoping client
Mon Jan 23 10:49:16 2017 user.info syslog: Closing USB device
