Hi, is qDslrDashboard compatible with 10.8.3?
It quits unexpectedly every time I try to open it. I don't have this sort of issue with any other apps.
Any thoughts on the cause? I'd love to try this program. Thank you!
Top of crash report attached…
qDslrDashboard won't run on OSX 10.8.3
- qdslr-crash.jpg (186.95 KiB) Viewed 10302 times
Re: qDslrDashboard won't run on OSX 10.8.3
Yes it is.
Please try this test build: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
OK, that one works terrific! Thanks very much!!!
mdal
mdal
daviddowns2000
I'm having the same problem with Windows 10 version 1511. If I try many times to open it, sometimes it will work.
