as subject states:
i own a D750. bought a MR3040, 2 new cables, updated to current dsldashboard firmware. checked with system:software that it was installed. system log gives:
Sep 8 16:46:10 OpenWrt kern.info kernel: [ 3738.610000] usb 1-1: new high-speed USB device number 18 using ehci-platform
Sep 8 16:46:10 OpenWrt kern.info kernel: [ 3738.860000] usb 1-1: new high-speed USB device number 19 using ehci-platform
Sep 8 16:46:11 OpenWrt kern.info kernel: [ 3739.110000] usb 1-1: new high-speed USB device number 20 using ehci-platform
Sep 8 16:46:11 OpenWrt kern.err kernel: [ 3739.530000] usb 1-1: device not accepting address 20, error -71
Sep 8 16:46:11 OpenWrt kern.info kernel: [ 3739.650000] usb 1-1: new high-speed USB device number 21 using ehci-platform
Sep 8 16:46:12 OpenWrt kern.err kernel: [ 3740.070000] usb 1-1: device not accepting address 21, error -71
Sep 8 16:46:12 OpenWrt kern.err kernel: [ 3740.070000] hub 1-0:1.0: unable to enumerate USB device on port 1
how do i resolve this? i would much rather use dd than built in wifi. or will i experience the same performance either way?
D750 MR3040 everything updated to current firmware, new cables, not connecting
Re: D750 MR3040 everything updated to current firmware, new cables, not connecting
How long are the USB cables? Can you try with the cable that you got with the D750?
Do you connect to the MR3040 full size USB port without using any sort of USB OTG adapter?
Eventually try and do another firmware update with the sysupgrade image following this guide: https://dslrdashboard.info/tp-link-mr30 ... e-upgrade/
.5m and 1.5m I did.How long are the USB cables?
I did. with both cables. did not work.Can you try with the cable that you got with the D750?
yes:Do you connect to the MR3040 full size USB port without using any sort of USB OTG adapter?
done. your sysupgrade image is based on 12.9.1 version of openwrt. the factory image is based on 14.07.Eventually try and do another firmware update with the sysupgrade image following this guide: https://dslrdashboard.info/tp-link-mr30 ... e-upgrade/
i still get:
Sep 8 15:44:18 OpenWrt kern.info kernel: [ 28.130000] usb 1-1: new high-speed USB device number 2 using ehci-platform
Sep 8 15:44:18 OpenWrt kern.info kernel: [ 28.380000] usb 1-1: new high-speed USB device number 3 using ehci-platform
Sep 8 15:44:19 OpenWrt kern.info kernel: [ 28.630000] usb 1-1: new high-speed USB device number 4 using ehci-platform
Sep 8 15:44:19 OpenWrt kern.err kernel: [ 29.050000] usb 1-1: device not accepting address 4, error -71
Sep 8 15:44:19 OpenWrt kern.info kernel: [ 29.170000] usb 1-1: new high-speed USB device number 5 using ehci-platform
Sep 8 15:44:20 OpenWrt kern.err kernel: [ 29.590000] usb 1-1: device not accepting address 5, error -71
Sep 8 15:44:20 OpenWrt kern.err kernel: [ 29.590000] hub 1-0:1.0: unable to enumerate USB device on port 1I tried installing your factory bin: DDServer OpenWrt MR3040 V2 Factory 0.13, and installing package through your instructions, but it would not install.
I also tried upgrading to 15.05 and installing package through your instructions, but it would not install:
ash: /etc/init.d/ddserver: not found
No packages removed.
Installing ddserver (0.2-13) to root...
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for ddserver:
* libusb-1.0 * uclibcxx *
* opkg_install_cmd: Cannot install package ddserver.
ash: /etc/init.d/ddserver: not foundStill with openwrt 14 and 15, with or without ddserver, the MR3040 cannot connect to the camera. I have connected the camera to my PC and opened dslrdashboard with no issues, so it is not the camera's usb port.
Here is with the latest OpenWrt version (this is for MR3040 V2)
factory: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
sysupgrade: https://drive.google.com/file/d/0BxMZ8X ... sp=sharing
Eventually you can try using a powered USB hub to see if it is power related.
